Hi everyone I have a 2001 raptor 660 and I had it up to 75 mph and everyone says there is this speed limiter that won't let it go over 75 mph. I was wondering what you could do to make it go over 75 without different gearing or sprockets. Could you remove this limiter somehow. Thank You everything is stock besides the K and N airfilter
    • By fwsamm
    • By nlee
      Do any of you have ATV's for your children or grandchildren?   My grandboys are fairly responsible, but they ARE boys!  The ride the heck out of this 4 wheeler.  Any suggestions what I can do to keep it running longer....?
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By mmikesell
