what temp should it be running i am putting a temp gauge on tomorrow and want to know bout what the temp should be my light has not came on but it seems that it is getting hot just the heat my fan it hooked to a toggle so it stays on the whole time it is running
Edited by bighoss
The temp should be between 200 and 205. If it goes above that the fan sensor will detect this and kick the fan in. If your fan doesn't kick in then the sensor at the bottom of your rad is gone or a wire is off. Hooking the fan up straight to a toggle could cause the engine to run too cold and this may result in a sooty spark plug.
    • By jhamrick75
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By DaleJAM
