    • By Sportsman500guy
    • By Werewolf
      Oil is getting in the air box from crankcase vent tube, I put the two hoses that go to the air box together then something started to smoke on the front of the engine. There is a filter? In the line I blew that out.
      he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point Raceway View the full article
      he fifth round of the 2024 ATV Motocross National Championship Series, an AMA National Championship, took place at High Point RacewayView the full article
    • By beast6228
      So the other day I picked up a Lakota 300, it's going to be a new project for a bit, the engine is super clean and so is the frame...luckily the VIN was intact.  However, it is the missing the air box (the one that holds the filter) but it does have the air chamber that goes to the carb.  These air boxes seem to be pretty pricey, so my question is has anyone had any luck running a pod filter on theirs and if so, what kind of jets are you running? The carb on this one is a Keihin CVK, I have yet to pull it off and inspect it.
