    • By Tinkeringreg
    • By kaidella
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
    • By pastorjeep
      Need some feedback here. I picked this machine up with PO saying no spark. I have tried new stator, CDI, and coil. The stator ohms 231 w/r to w/g and .1 red to blue. The coil is .8 primary and 2.53 secondary. I have 12 to the CDI with ign on and the wires from stator to CDI have good continuity. This model only has 12v on or off for ign/kill source. Still no spark?
