I only started riding a few months ago. I'm very late to the game and have almost no experience riding, besides growing up on utility quads that I never had to work on and never left the ground with. I also have almost zero mechanical knowledge. But I'm willing to learn and my google-fu is strong. I also have a buddy that's willing to help me out with installation of new gear (even though he's just learning himself).
After nearly two decades from the last time I rode, I decided to pick up a couple quads for the family. I wanted a sport quad for myself, so I got the KFX 450.
I took it on a few trail rides before I got the balls to take it out to the motocross track. Out there, though, I'm finding that stock just isn't enough. Well, it's not completely stock. It has a steering stabilizer on it (whatever that does), and a few other small, non-performance based aftermarket parts. Oh, and I'm also running a 37 tooth rear sprocket. But it just doesn't seem to have enough power to hit the ramps at nearly the speeds that others are hitting them. Especially when I'm coming out of a turn followed shortly by another jump (admittedly, though, I'm sure some of that has to do with me being a bit of a sissy out there. This track is pretty scary. I don't have any small practice tracks near me, so I have no choice but do ride the big boy track).
I guess what I'm looking for is this: The bike has a high top-end speed (like 75). I don't care about top speed. I rarely, if ever, need to break 45. I need a way to get the bike going much faster off the starting line. I'm extremely willing to put in the research and the work, I just need a good starting point from people that are much more experienced than I in these matters.
I have money to spend, but not much at this very moment (I just dropped $1,500 on a new PC). Right now, I could probably drop $200-$300. If need be, I could probably afford $400-$500 a month in parts. I'm not saying I want to do that, but if I needed to save a bit to get parts, it's doable. I'm just trying to let you know my budget.
What I'm looking for are suggestions on parts to get this bike faster off the line. Remember, I don't know anything about engines, so I apologize for the fact that you'll have to talk to me like a child. To be honest, I usually blindly follow knowledgeable forum users in these situations, but I'm very rarely let down. If I can find some suggestions on parts, I can buy them and work out the details later, the same as I do for many other things.
I appreciate any advice you guys are willing to give. Thanks.
I would start with a manual not the owners manual but a manual for working on the quad It will help you and be your best friend somethings you need speciality tools for some jobs. The sprocket may be a good start but also comming out of a turn and into a jump are you down shifting to a lower gear to get that bottom end power you need for the jump. A kfx 450 should have good power. Do you know if it's a stock exhuast pipe. Changing the pipe can help with getting more power, If you have a carb & not fuel injection you will need to rejett the carb along with a pipe change also an air filter change can help by using a performance filter as well. What has been done to the quad that you know of any boltons etc. There is so much that can be done to a quad you need to get an ideal of what you want out of the quad as performance goes. A steering stabilizer on the quad keeps it from jerking the bars out of your hands when the front tires hit tree roots, rocks , bumps & landing off jumps other words be happy you have it it makes for happy hands & arms after a day of riding. It does sound like you have the power you need but just not where you want it I would wait for other replys & ask others at the track what sprocket size they use as well.
At this point I would get used to riding the kfx. Its a fast quad and plenty fast for an mx track. Before you get your go fast goodies get your riding gear in check. Get riding boots not work boots. Get your body armor also especially at an mx track.
Sent from my SGH-T989 using Xparent BlueTapatalk 2
i would start with a programmer and muffler ... then maybe a clutch kit
heres a programmer ... JD Jetting Dirt Bike Fuel Control | MotoSport Canada
heres a slip-on muffler ... HMF Dirt Bike 4 Stroke Spark Arrestors | MotoSport Canada
heres a clutch kit ... Driven Industries Dirt Bike Clutch Kits | MotoSport Canada
these are just a random selection. you can shop for better and less expensive
heres a good review of your bike ... 2008 Kawasaki KFX450R Review
Here is my thinking when we buy a used quad we don't know what has been changed. We do know people tend to setup their quad for the style of riding they do. So there could be a chance of a sprocket change or not. I would find out what it came with from the factory and check to see if yours has been changed for more top end performance if it's not been changed I would put in more riding time because the performance should be there and just be a matter of learning to use it like mario & I said riding skill is needed knowing when to shift gears & use the clutch & gears to your advantage. If your riding at a track and your quad seems slow compared to other quads talk to those guy's ask ?'s they may race at that track and have years of experience. If you have more power & torque you still have to know how to ride to use it and to be safe. Your riding skill needs too match the quads performance or be above it is even better. There is nothing wrong with being a wimp at the track but more performance isn't going to help that. It will change in time with riding. When you get to where your riding and using every bit of the quads performance or as your skills start growing then look at taking the quad too the next level it's not all about power you need to think about suspension upgrades as well better handling makes for faster track times. Look at it like this if you put a 800 hp race motor in a stock street car your not going to be able to use the full 800 hp. until you build the rest of the car too handle it. I know you may not want to build a race quad but the ones you say are faster at the track could be far from stock that your comparing yours too!
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
      Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
      It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with  electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
      Does anyone here have any expierience with these.
    • By motox88
      What are your riding location preferences? Mud Park? Personal Trails? Public Land?
