I charged my battery on a 87 yamaha timberwolf 250 and left the key on like a dummy. Now that i have a battery that is fully charged i have nothing when i hit the start button. I can jump the stator and have spark but dose not turn over fast enough for it to start, I have no lights or anhything. I checked for fuse but the is no inline fuse someone chopped it out and spliced it. I used to turn the key and have the neutral light on. But no light and when i hit the start button i get nothing. What could my issue be?
on my big bear, it is behind me (sitting on the bike), on my left hand side, away from the cylinder and more on the transmission. its just a single wire running to it. much like a temp sensor or oil sending switch on a car engine ....
thanks i found it! I was looking at it the whole time! LOL But Im gunna clean connections and see how it turns out. Is there a way to bypass the switch?
check the reverse lever and make sure that it is locked in place, and also check your starter solenoid
Edited by YFB250E
    • By Tinkeringreg
    • By Mhatayas
