By motox88
Anyone have bad experience with these clutch kits? Looking to get one for an 80s quad that I have.
By anthonyd256
I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
By Starsat
The choke lever doesn't stay in position on my 2001 Yamaha Kodiak. The model is YFM 400. I have to hold the lever to the choke position manually for some reason. Any Ideas as to why?
By joshua91673
hi every one .anyone out there my issue is my kick start wont stay out i have to have some one pull it out. it pull out easy just wont stay out to kick it over .kicks over and starts no problem
also does this quad have a ajust mint for the rear spring .it sags when i get on it .or is this normal . thanks guys for your time
first post
josh ohio
By dvs1961
Just bought a new hisun ,been shopping for a year or more for a sxs best bang for the buck...Are there any lift kits out there for a 2022 Hisun 750 sector ? links thanks
