By BuckBilly
By ATVNetwork
By PIYIRIO
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By Snick
^PINOUT:
5 6
2 4
1 3
