Here's one on ebay for $100. Not all years interchange, but if you go to cheapcycleparts.com and look up the part number for yours and the one for sale, it will tell you if they are the same part number and will therefore interchange. If that one for $100 fit, IMHO grab it. They don't come up real often. Usually by the time you need one, so does every other one made that year unless it was garage kept and babied. In which case they probably aren't parting it out, but still driving it.
Most years the KingQuad and LT-4WD (or 250 Quadrunner 4x4) will use the same muffler.
http://www.ebay.com/itm/98-Suzuki-LT-F250W-Exhaust-Muffler-/271116939185?hash=item3f1fd42fb1&item=271116939185&pt=Motors_ATV_Parts_Accessories&vxp=mtr
Edited by catcandu
forgot link
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
