By mga
I just saw a video on TikTok where some guy took the rear end off an ATV and bolted on a roto tiller in place of rear wheels. I wish i saved that video to post here....good thing it was 4 wheel drive...lol but, it seemed to work.
I'm not sure how he made it bolt on to the drive....
By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
By prdicon
South Florida.
How much it worth?
Pros: looking decent.
Cons
No brakes.
Front wheel bearings are shot.
Idles, but sometimes will shot off. Most likely when cold.
Gas smell and little bit steam in the air filter box when I started it.
Display screen won't work.
Tires are dry with cracks.
Not sure if has title, I will check and update.
How much do you think it worth?
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
