Not sure but I think its using oil. The engine always does this no matter how long it runs. The engine was running about 30 minutes in this video.
[ame]
[/ame]
The exhaust will blow out carbon also when reved up.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
are you going thru a noticeable amount of oil? have you checked the valves yet?
Valves are adjusted. As for a noticeable amount no. But the plug gets fouled a lot also.
I was using some seafoam cleaner in the fuel also. This could maybe ruin the plug i guess. But the white smoke is my main issue i guess.
I am seeing seafoam can cause all the smoke.
Edited by DerkS
what does the smoke smell like? oil or fuel? how does your oil look (milky?) and what weight are you using? how are the vent lines from the crankcase to the air filter box? is there oil in the filter box?
Smells like fuel. Oil looks fine. It it 20-50w with some Lucas oil additive. Vent lines are fine. No oil in air box and filter is clear.
    • By Mhatayas
    • By jhamrick75
      What oil does everyone like to run in the older quads?
