(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
This is an amazing 2011 Can Am Spyder Sm5 RSS with only 1970 miles on it.This Can-Am is in pristine condition and runs awesome. It is full of power and it's in amazing condition. I'm the first owner. Garage kept. The wheels are awesome and the rig needs n...
More...
    • By jwh
    • By TimothyLindblom
      Timothy
    • By Coyote251
      QUADCRAZY NEEDS YOU!
    • By Hagbard
      Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
      After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
