Just got a used Susuki 300 (2000) and am goin' through it changin' the fluids and filters.
Can't seem to find a fuel filter, does it have one and if so, where is it?
if you dont see a filter on/in the fuel line going frm the tank to the carb then it dosent have 1 ... there should be a screen in the tank on the fuel stem that is on the inside of the tank ware the fuel line go's into the tank .. r on the fuel shut off if its mounted to the tank ... if you want a filter you can add 1 inline between the tank and carb...
    • By Tim Keiper
    • By Trent Finnessey
    • By Randomnumber73
    • By DPDISXR4Ti
      Thanks...
