If You Tow...
By neilroy87
By carkivey3
By Derek4518511
Mid 80's 340 artic cat is going into a go cart just for fun i bought a new cdi unit the original plug was cut off when I got it. there is 5 wires 2 yellow, a red a white and a brown my new cdi has 5 also a lt/green a blk/wht abrwn, a black a blu/grn is there a wiring diagram I can use for reference or which wires go where a y help would be greatly appreciated jated. BTY I'm Derek and new to this forum I am actually trying to help a friend with project and learn a little in the process
By Patrik1543
Good day, I have an atv 150 raptor with a bemi engine from 2002, at least that's what the label says, the problem is that it doesn't have electricity, I bought it completely new and nothing works except the starter relay, so I'd like to make it my own and with my own hands, I just need you to help us get a diagram because I can't find anything on the internet that would answer my idea, the quad bike has a 4-pin cdi and a 4-pole rectifier and a digital tachometer.
