i was always under the impression that it is alot less hard on an atv or vehicle to switch stopped or at a crawl. but new technology advertises shift on the fly ... i'm old school, i stop and shift. what does the owners manual recommend?
Edited by oxidized_black
can-am recommends to switch at low speeds ..and with out the rear tires spinning in mud or loss of rear traction.. but i have seen it done at different speeds and while spinning the rears in mud ... but have heard noises that didnt sound good on there machines ... so i would say shift at your own risk at high speeds and durring rear traction loss ...
    • By Coyote251
    • By oxidized_black
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
