2000 yamaha bear tracker 250, started out firing fine just wouldnt start so i replaced the jerry rigges intake manifold with a new one from yamaha shop, now the bike wont fire, so then i checked fuses and everything looked good so i go to try and crank again and now i have nothing the bike wont even kick over electrically.
if you pull the plug and pull start, is there spark?
if all the fuses are good, there might just be a bad wire somewhere or broken ...
are there dash lights on it? are any of them lighting up?
a loose or broken neutral/safety switch will stop the fire for plug ...
    • By Thumpinhard25
    • By Trent Finnessey
    • By Tinkeringreg
