Hey there everyone.
Father in law picked up a used 2000 BB400 4x2 - motor runs well, no smoking. Little cold natured, but starts easy enough on full choke, and as it warms up you can back the choke off to a normal idle. Not uncommon for older carbed bikes/quads.
but - cold or hot, this thing is sometimes a real pain to get into reverse or 1st without rocking it back and forth a good bit. as it warms up, again it acts better,but doesn't get perfect.
When moving,it shifts up and down smoothly and accurately with no signs of clutch slipping.
Oil looks good and clean.
I see the clutch adjustment on the left side crankcase - but before I go screwing with anything, I'd like some other's opinions on what I might do to make the engagement easier.
thanks,
Chris
    • By Trent Finnessey
    • By Randomnumber73
    • By TimothyLindblom
      Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
      The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
      He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
      I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
      Any ideas on what it could actually be?
      Timothy
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
