By Randel1
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By Joeguy
So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
By Derek4518511
Mid 80's 340 artic cat is going into a go cart just for fun i bought a new cdi unit the original plug was cut off when I got it. there is 5 wires 2 yellow, a red a white and a brown my new cdi has 5 also a lt/green a blk/wht abrwn, a black a blu/grn is there a wiring diagram I can use for reference or which wires go where a y help would be greatly appreciated jated. BTY I'm Derek and new to this forum I am actually trying to help a friend with project and learn a little in the process
By mcmoose
Hi all, Ive got a Hisun 400 quad and have p[osted before , thanks to all who answered and helped!
I need a coolant recovery tank for this quad, i believe its a yamaha grizzly copy , the thing is the tank is not shown on any hisun manuals i can find, and looks different to what i expect on the yamaha pages. (the original part has been lost). Does anybody have a picture of the recovery tank in-situ on the early 2000’s grizzly ? This quad is killing me!
hope you can help solve this final piece in my puzzle.
