Help Identifying Old Yamaha Quad?
spencex
I have inherited a Yamaha quad but there is no model number on it that I can find--which I need in order to get an oil filter for it.
It has a 4-cycle, carbureted, air-cooled engine and its very basic--no speedometer, etc. A friend thinks it might be a "300."
I would appreciate any help.
Thanks,
Spence
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
    • By Need-help-with-quads
      Can anyone help me?
      Anybody got a service manual for a 1989 Yamaha moto 4 250?
    • By ResQ91
      Hi guys
      battery and connections good
    • By Werewolf
