This is a line of ATV's thats been carried for over 10 years, Most the same frame/engine correct? I know this engine design is also used in other atv's, Not sure which ones though, There must be some mod's that people have done? Even mineut changes, Post em here! Would like to get ideas for mine and see what other people have done.
  • 2 years later...
    • By Ethan7387
    • By marcosphoto
    • By cameronokeefe6
      I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
      I was thinking on getting a 200x piston, will this work and give a good power increase ?  I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
      I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
      If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
    • By heath
