Noticed it this morning, Was -1 out, Started it with choke half way open, Fired right up second crank via electric starter. Shed was filling with not exhaust but oil/smoke, thought nothing of it at the time, Fast forward to later today, Started it up after washing it, And got a big puff of smoke from the bike, Checked the oil, Sure enough was down about half a quart, Opened air box, Oil sitting in the bottom of it (could have been from the prefilter though but there was an oilish trail from the intake tube which the breather connects to) Breather tube has milky white oil (I know it means water) Any ideas or help would be apreachiated, It has great compression which strikes me as odd considering its used half a quart of oil in about 5 hours run time (Have a hour meter)
Only has one vent line off the crankcase, and it does not seem to have a valve so its constantly getting pressure out it, I have a feeling thats where some of the oil in the air box is coming from,
I noticed this as well on my 1990 Big Bear after full fluid change and filter cleaning. Before the oil change, zero smoke at start-up/idle.
Afterwards, smokes a bit on initial start but clears up after warmed up.
Kind attributing to the fact that maybe poor oil circulation due to very clogged oil filter in my case and age of the bike systems.
Planning on valve adjust but not sure that will make any difference in start up smoking. I'll be watching for additional tips too.
    • By Arizona
    • By gwares
      Price : 2500 EUR
      The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
    • By Winnem
      Hello.
      I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
      Is there anyone here with experience, or know a good solution on this?
