the carb is probably still plugged somewhere. compressed air seems to be the key after it's cleaned. when you clean it again, use some twist ties from garbage bags, (stripped) and run them through the small passages. also check the rubber manifold for cracks, the rubber that goes from the carb to the block ...
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
    • By jhamrick75
