I'm having trouble with the E-ton thunder 90. The electric start has stopped working & for a while the horn would still work but has stopped as well. List of what I've done so far. Made sure the battery was good even tried my battery from my quad tonight & it did nothing I cleaned all plugin connection and put dilect grease on all of them. I pulled the starter and put some juice to it and it works. I pulled the housing apart for the horn and starter button it's good and clean inside. I checked the fuse on the hot wire comming off the battery It has the spline part comming out the side cover for a kick starter so I used vice grips to start it and checked the kill switch button it works and the key switch is working. I don't see any other fuses I can change unless their covered up. I have no owners manual for this quad.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Tinkeringreg
    • By kaidella
    • By Ethan7387
    • By mmikesell
