    • By Trent Finnessey
    • By k9_bones
      Hello, been lurking for a while fixing some of my problems after reading others unfortunate issues. However I can’t find the answers I need. Back story I have a 03 Kodiak 450. A coworker was going to take it to the dump, he said it wouldn’t run. Some mice got in there while it was stored for a few years and chewed up the wire harness. All the wheels were locked up and he didnt want to mess with it. Not knowing if it would run, for a week or so I spliced most of the wires back together. Replaced all the brake calipers and rear brake cable and rebuilt the carb. So far I have put 30ish miles on the bike and seems to run decently. Now my questions. When I put it in gear and the display light showed it is in gear I have to bump the throttle to make it actually go into drive or reverse. It doesn’t slam In gear but kind acts if you let the clutch out to fast on a manual. Is that normal, seems it’s thinking about going In gear then it goes after tapping the throttle. 2nd question, when I use the diff. Lock it acts like it is in a limp mode just by accelerating the lest little bit. It starts to sputter and won’t allow it to have any power. It only does this with the diff lock on. 3rd. The display is stuck on KMH. How do I change it to MPH. I followed all the steps I saw on YouTube with no luck. When I got power to the display it was in MPH but it switched its self and now I can’t get it back. Next are the rear u-joint the same as the front u-joints. I have sprung a oil leak from the rear diff at the drive shaft and need to replace the seal. Sorry for the long post and thanks in advance for any help. I’m sure I will find more things in the future.
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By Werewolf
    • By brettautosworldwide
      Sportsman 450 H.O Whatsapp : +33758980374
      Starting at $3,999 US MSRP.
      Plus logistics surcharge of $250.
      Plus destination charge and set-up.
      Reliable Sportsman power, performance and comfort—all at a best-in-class value.
      For inquires : [email protected]
      Instant chat Skype id : live:.cid.481378ea1a91ce4b
