I just got this wheeler it runs and drives good it has a 2inc lift with 26inc tusk tires on it the only thing is that the front tires pigeon toe out. it has new balljoints on it and nothing looks bent is this normal or not?
There should be specs in the owners manual for toe in/out. Just use a tape measure to measure from the center of one wheel to the other wheel's center in the front and then back of the tires. The diffrence is your toe. Also make sure you have the handle bars straight when doing this, it is easier if you use a tie down to hold them straight.
      Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
    • By JMSwed
      Hi EVERYONE
      New member here
    • By mmikesell
