What's Up!, I'm Currently in Afghanistan, working on mostly Polaris and Kawasaki. I in the process of a 2005 Polaris Sportsman 6x6 rebuild, the frame was cracked, so have to switch everything over, thought I would fix all the broken stuff at the same time. They get a lot of use over here, with the sand , it can be difficult. I'll try to be on to help other members out, and ask questions, when i can't get it. See everyone around.
    • By oxidized_black
    • By Kawasakibayounospark
    • By neilroy87
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
