I have a Kawasaki prairie 650. It has about 500hrs. Anyway I changed the front differential oil and I noticed it was slipping. As I turned around to head home my front end became extremely wobbly. As I slowed down to baby it home I heard a really loud bang. It made it home but barley. Nothing visibility broke so I'm figuring the differential locked up. Can someone please lead me in the right direction. Thanks
    • By Mhatayas
    • By Kawasakibayounospark
    • By neilroy87
      Adding to downloads library.
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
