Yep definately makes me want to go out and buy a sport quad.
Yup, they're a lot of fun! I really like 4x4 quads as well because of all the mud they can go through and the insane distances you can reach with them, but although sport quads can be fairly limited on distance in some trails they've got the pros and cons as well, I really enjoy ripping through the trails at high speed or tearing up some sand hills!
    • By marcosphoto
    • By Coyote251
    • By huntindog
      TIA
    • By BenJammin
      I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI.  service manual only talks about leak down test.  No specification for engine compression the manual.  What does 75 PSI tell me?  Thank in advance.
      A little history of this machine.  640 miles.  Picked it up about 2 years ago, not running. Probably the computer.  Tested all circuits and confirm it was the computer.  Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs.  BUT, it tops out 20 MPH.  I cleaned the carb 3 times also using a Mikuni carb kit after the second time.  Slide in carb is going up and down.  Only adjustment for fuel is at 1.5 turns out.  NGK Sparkplug had soot on main part but brown on the electrode.  Champion sparkplug is brown.  I check CVT clutches and they both appear to engage like they suppose to.  Checked valve clearance it's 0.00, I can't get any feeler gauges in-between.  I check timing chain I believe it's in the correct position and hasn't skipped.  I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
    • By Sofaspud
