I recently was given a 2005 Chinese ATV, No marking what so ever other than on the side of the head it says 10cm3, which i think means that it is a 90cc? Trying to figure out which cdi it needs, as I have diagnosed that i am only geting .1 v at the coil, it also has a alarm (no fob) which ive read you can just unplug to bypass, i have the vin number it is l5nsumcc45t009855 but that isnt helping much... The motor cranks, but no spark checked the kill switches etc.
Edited by trieck1232
hit enter early
Think its a fushin
falcon
MOST LIKLEY THE CDI
IF EVERYTHING SEEMS OK AND NO SPARK
REPLACE THE CDI AND IT SHOULD FIRE UP
BUY SOME EXTRAS THERE ONLY COUPLE BUCKS AND ALWAYS GO BAD
  • 8 years later...
That has a AC cid almost any thing new ish does just makes sure the cid you buy has the same plug or plugs some toke a single square connector some have 2 plugs
    • By Panupong Pradchaphet
