i have a 05 yfz with a brand new battery. There is an issue with it not starting now. You can hear the cliking noise but no turn over.Battery is charged fully but no start.HELP!!!!!!!!!!! What is the problem or anyadvice to fix and not go broke in the process
took screwdriver and attempted to jump start and NO DICE! NO SOUND NOT ANYTHING! But will follow the advice given and hopefully progress. The weather is to nice to miss out like this. Plus, my neighbor has a Raptor I want to embarrass real bad.
Put a meter on the leads and make sure you are at least getting 12v to the starter. If I remember right even when you jump the starter there usally is a spark or something.
Check the ground wire and make sure it has good contact with the frame.
I would pull the starter and directly wire it to a 12v battery and see if I can get it to turn if the above does not work.
    • By Dumass
    • By fwsamm
    • By JMSwed
      Hi EVERYONE
      New member here
    • By Dsluder
    • By Eisaks777
