Front sprocket, tires, rear sprocket, larger carb, drag pipe, cams, oversize piston, head porting, larger valves, striker crank, etc. I could go on all day. It depends on your wallet, how much can you spend. Why do you care about top speed? That's not what wins races...
I'm just sayin, why use the EX as a base quad? I do understand that's what you've got for teh time being, but, say you sell the EX for $3,000 and you have $2000 to spend on mods to make "the top speed" higher. So, let's just say you've got $5,000 to work with. For 5g, you could get a 80HP+ banshee that'll kill on ANY 400ex.
Banshee- $2000
CPI Pipes- $450
32mm Carbs- $350
VForce Reeds and Filters- $350
Quality Agressive Dune/Trail or Drag Port- $500-ish
Bore/hone Cylinders- $150
Wiesco Top End Kit- $300-ish
NOSS Head and Domes- $250
4mil Crank- $400
Override Transmission- $300
All that totals $4,950, rough prices, I estimated on the high side too.
    • By Trent Finnessey
    • By Dumass
    • By carkivey3
