Thanx for the information. Much appreciated. I was able to locate the diode and it has failed open. Does anybody know where to purchase a fan diode from? They want $640 for a complete harness. I diode is worth about $5.
Off the top of my head you are looking for a 10 or 15 amp blocking diode with axial leads. Check Online or Radio Shack.
Radio Shack does not sell a 10 amp diode but they do sell 5 amp ones and what you can do is they come in a 4 pack or something like that. Solder two in parallel and that will double the current it can handle. Make sure you have the polarity correct when replacing it.
Swampcat is right, the diode is inside the wire harness near where the fan connection mates into the harness.
Mike
Thanx guys for the info. The PN junction of the diode turned out to be okay. The Anode actually broke off and the cathode was barely hanging on. A little solder and some patience and we are back in business.
    • By RussB
      Flywheel puller. Does anyone have the size as the part #529 036 049 is non existent
    • By carkivey3
    • By Sportsman500guy
