can't get any spark to the plug. put in a new ignition coil, and a new c.d.i. unit.
still haven't got spark. also checked the wires for and breaks and checked both kill switches with ohm tester. they both seem to be working ....
does anyone have any ideas.....
mike..
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
