well my 05 king quad 700 has been running good on a honda rancher 350 carb, except it wont open up all the way, it has enough power to sling mud bout 50 feet, but, its just choking down, the intake through that carb is too small, jets too small, it has not overheated, it has not made the exhaust glow, hasnt missed a lick, just wont get over 42mph, it has plenty of lowend power, just like i said, not enough air or fuel to make it have full power, i found a carb off of a 76 ford 300 6cyl, it is a large bore 1 barrel, it is capable of running a 4.9l engine, going to rebuild it, cut the square flange off the bottom, while its apart i will weld a round bottom collar to attach it to the original throttle body mounting boot, hopefully by tues or wed it will be in place of the honda carb and the king quad will be pulling the front end off the ground, will post updates as available
OK, i found the carb im going to use, its a holley 2 barrel, approx 400 cfm, i will fabricate permanent base to mount it, adjust the fuel flow or rejet it with slightly smaller jets to keep from washing the rings, this carb is more than capable of running this king quad to it full potential!!
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Trent Finnessey
    • By Dumass
