By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By qcm413
Hi,
Thanks for a newbie on this site !
i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
thank
By DGBear
My front brakes started dragging and the lever travel was minimal. I bled them and topped off the fluid reservoir and they worked great for a while and now the problem has returned. I'm thinking that a piston may be sticking. Any thoughts on this problem?
By pastorjeep
Hey guys, I just picked up this quad that hasn't run an a few years. It is missing the front drive shaft. Does anyone have the can measure for me or know of a replacement? If I can get the dimensions I can try to use one from another machine. Thanks!
