that is a great view. good thing it stopped when it did. thoughs trees probably would have torn it all up. good that everything worked out and you and your quad are ok.
I admit it, when we got it out and after seeing where it was and where I had been thrown when it happened, I said a prayer of gratitude.
It takes me about an hour every morning to get my knee loosened up enough to walk.
Any accident without a histpitol is a good accident.
I'm I the only one that gets bugs in my teeth cuz of the perma grin on my face while riding a quad?
    • By dalton7545
    • By DaleJAM
    • By DonB
      Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator.  Must I spend the $750+ for a new assembly from Arctic Cat?!?  Here's what I've tried so far.
      Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists.  I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly.  When I can temporarily get the PSI right, everything works great.  Anyone else ever dealt with this problem, and, if so how did you fix it?  Perhaps I should adapt the fuel system to include a gas tank return line?
      Any insights are greatly appreciated, Don
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
