my arctic cat 700 has fuel, and air but no spark.... i was riding it one day n it backed fired n shut down on me tired to start it up again n she wouldnt start... i waited a couple days she started right up ran for 5 minutes then shut down again... now she wont start at all any suggestions?
Check and make sure you have power to the Coil and spark plug also check your key switch is working correctly. Change out the spark plug and see if that helps.
It may be a short under the rear plastics or near the front handlebars where they go through the black plastic.
Other common problems for the 07 are the magnets on the flywheel and the starter.
Take a look at the wiring first and let us know what you find.
    • By Gunny
      Hope you enjoy the video ....
    • By Tinkeringreg
    • By Kawasakibayounospark
