How to buy a new ATV Article:
How to decide which ATV is best for you.
The Bottom Line Research, Research Research!
Buying a new ATV is like buying a new car. There are many things you must take into consideration before making your decision on what to buy. The more research you do, the happier you’ll be with your purchase. Price range, intended use, local riding conditions, and riding experience are just a few of the most important things you'll need to think about before deciding on what you want.
For instance, I personally own a 2000 Polaris Scrambler 400 4x4. I determined that this ATV was the one that fit my needs best. The price was one that I could stomach paying (some ATV retail for over $7,000 when they first hit the market), the 4x4 feature worked well on the hills and in the mud of Pennsylvania, and the 2-stroke engine gave me the snappy feel that I didn’t want to give up by going to a 4-stroke engine (which is what most, if not all, other 4x4 ATVs have).
PRICE
Price is probably one of the biggest factors that most of us will have to consider. Most new ATVs that an adult would ride, range in price from $3000 to $7000+, that’s quite a difference in price. Also, don’t completely rule out buying a used ATV, most dealerships carry a few used ATVs that they accepted as trade-ins. You may also be able to find a really good deal on a used ATV in the local paper or community bulletin board.
A few things to keep in mind are: A four wheeler with 4x4 will tend to be more expensive then the same model without 4x4 (2001 Polaris 500 4x4 retails for $6099 Vs 2001 Polaris 500 2x4 retails for $5449). The bigger the engine, the more expensive a particular model will be (2001 Kawasaki Prairie 400 4x4 retails for $6099 Vs 2001 Kawasaki Prairie 300 4x4 retails for $5399). More options means more expensive, ATVs in the 4x4 class that can efficiently push, pull and ride comfortably will cost you more then the ones that don’t do these things as well and on the other hand, in the racing class of ATVs, the faster, lighter machines will cost you a pretty penny as well. These are all things you must consider when deciding on what you want.
INTENDED USE
Intended use is the next big thing you’ll want to consider. For example, you probably won’t want to buy an Arctic Cat 500 4x4 if you are looking for a machine that is agile enough for racing and light enough for speed and agility in the turns. This machine just wouldn’t serve it’s intended use very well, therefore you wouldn't be happy with your purchase in the long run (which, by the way, would be an expensive one; 2001 Arctic Cat 500 4x4 retails for right around $6000!). On the other hand, you wouldn’t want to buy a Yamaha Blaster to use around the farm to pull hay or push snow (Yamaha Blaster retails for around $3000).
If you plan on towing things around on your property or farm, pushing snow or dirt, or using your machine for hunting/fishing, you may want to consider a 4x4 machine. There are less expensive 4x4s on the market, but you probably won’t find one for less then $5000 new. This is a situation where you may want to consider looking at used machines, you can find 4x4s that are a few years old for around $3500-$4000, depending on mileage and condition.
If you are planning on going dune hopping or strictly racing your machine, you’ll definitely be looking at the major race machine manufacturer’s like Yamaha (Blaster, Warrior, Raptor, Banshee) and Kawasaki (Lakota, Mojave) just to name a few. These companies offer lighter, more nimble ATVs then Arctic Cat, Polaris and Suzuki.
LOCAL RIDING CONDITIONS
The topic of local riding conditions is probably just as important as intended use. Mainly because, you may have the desire to go dune hopping, but if you live in Nova Scotia, hopping from dune to dune will be a pretty tough feat to accomplish! For example, I really missed my old ’85 Suzuki 250 Quadracer, but I knew that I probably wouldn’t be able to enjoy it like I did when I was younger. Now all of my friends have big 4x4 machines and they like to ride them in places that require 4x4, if you know what I mean. They’ll literally go through every and any mud hole they see, and they try to climb just about any hill, no matter how steep it looks, so a high strung 2-stroke just doesn’t fit the bill very well when we go riding on the tight, muddy, hilly trails here in PA.
Even though I gave in to the fact that I probably wouldn’t be able to get the most out of a Banshee or a Warrior here in the northern hills of Pennsylvania, even as much as I would have liked to have one, I still couldn’t shake the desire to have a little bit more snap in my machine then what a 4-stroke offered. The 4-strokes seemed so bland when I test-drove them, they just didn’t seem to have the same “get-up-and-go” as the 2-stroke Polaris 400 4x4 that I drove. So, as you can see the Polaris fit my needs pretty well, it was a 4x4, but it had the 2-stroke engine that I wanted and I really didn’t plan on doing much pushing or pulling with it, so it turned out to be the right machine for me.
RIDER EXPERIENCE
Rider experience is listed last here in my epinion, but certainly is not least on the list of things that you should consider when purchasing an ATV, especially if you’ve decided it was time to get one for junior. Kids love to have what their favorite riders are riding on TV, and most racing machines are quite dangerous. If your buying an ATV for your son or daughter make sure you research the topic well and all the machine's specs before you make your decision. Don’t just take the recommendation on what little Timmy or Suzie wants, because what they may want could turn out to be a high powered racing machine that’s made for experienced riders like the ones they watch on TV (Banshee, Warrior, Raptor, Lakota, Mojave, Cannondale, etc).
Above all, no matter which machine you decide to purchase, make sure all parties that will be riding it goes through a certified training course on safety and use of the machine. I believe it is mandatory in most sates now that an onsite safety training course be given and a video on the dangers of ATVing be watched prior to the final sale from a dealership. Believe me, this isn’t even close to being enough preliminary experience for someone that has never ridden an ATV before, I would highly suggest that you look into more extensive training courses on rider safety and ATV use.
This one doesn't even need a long paragraph to explain the reasons why it is so important...........if you want to live, wear a helmet and eye protection at the very least. Chest protectors and riding gloves are highly suggested, and other riding gear like shin and elbow pads, riding boots and outfit wouldn't hurt either. Also, never ride two riders on a machine, this is becoming a law in most states now.
FINAL NOTES
The categories I have previously suggested are just a few of the things that you should consider before deciding on what you would like to purchase. There may be other things that you will need to think about before you make your final decision. The most important thing to remember though is to make the decision that best suits your needs.
A little extra research in the beginning will pay big dividends for years to come, but on the other hand, lack of research could lead to a poor decision that you may regret for years. ATVs are a lot like vehicles, as soon as you haul them off the lot, the retail value begins it’s ever ascending plunge to nothingness. So, make sure the ATV that you’re towing away is the one that you really want.
RESEARCH
Here are a few links that you can use to start researching which ATV is best for you (you’re on one of them right now!)…………….. Polaris : International Portal : Home.. America's Most Diverse - Yamaha Motor Corporation, USA, Home. Kawasaki Motorcycles, ATV, Jet Ski Watercraft, Utility Vehicles. Arctic Cat®.. www.suzukicycles.com...... ATV Connection Magazine Home Page
Good luck and I wish you all the safest, happiest ATV riding for years to come!
Epinions.com - How to decide which ATV is best for you.
He forgot to mention the last catagory.....
IF YOU HAVE SACK:
You may want to consider the Big Mack Daddy of the Sport of ATVing..The Yamaha, Honda or Kawi. ATC 3 Wheelers...Not only are they Faster than anyting on the Show room Floor but they are the best Bang for your Buck....
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Panupong Pradchaphet
