I have a 2007 suzuki LT-A450X 4x4 which has two problems which i hope someone has an answer to help me out. First the bike has a hard time cranking up has new battery and turns over just fine but it takes turning over many times to start up and now i need to spray starting fluid in the air filer to start and it seems to like being pull started instead of the starter ??? Second when i do get the bike cranked up and drive it at high speed it pops out the exhaust??
Edited by CRASHTOWN
i got tired of messing with the fuel injection on my 05 king quad 700, i done away with the throttle body, installed a carb, i have not had a minutes trouble since, used to be scared to ride the bike cause it would be likely to shut down on you any minute, now you hit the starter button and it fires right up, an runs great
    • By Tim Keiper
    • By Frank Angerano
