I have a 2007 KinRoad Quad 200cc ATV.
It was running great and then acted like it
Was flooding out and died. I smelled gas
and the air filter was flooded with gas so
I ordered a new carb, bolted it on....
Nothing!!! pulled plug and no spark so..
I ordered I new coil, CDI box, and plug.
After installing, turned key.. Nothing, still
No spark. So I ordered a new 12 coil stator
and just knew this would fix it, still nothing.
I just checked all my wire connections
and found 2 pins in one of my connectors
wasn't fully seated so fixed that, still nothing,
No spark!!! Help!!! I don't have a wiring diagram
For a Chinese ATV so no sure what else to do,
felling really stupid right now!!!!!
I have a fluke muli meter but not the best
at using it and not sure about where to check and
what input/output values should be coming
from from engine (CG200cc)
Welcome to QUADCRAZY. Did you reach out to them and see if they can send you a wiring diagram? There could be an ignition relay or something or bad ground. I don't think the issue is the carb.
New coil and all and still no spark, could be as simple as a bad ground.
Yeah I'm starting to think that it may be
and neutral safety switch or something
Simple because none of this makes sence
To me. I don't have a kill switch like bike because
I have a key switch mounted on fender
and checked it and it's good. Going to start
adding new ground cables to make sure
Frame,engine are grounded good.
Being in the Aerspace field, we have lots
Of that stuff. :D.
Edited by Fordmtrsp
Oxidized-black, THANKS SO MUCH!! I feel
Alot better about that!!! :)). Going to put the
case cover/stator back on tonight and
get back to trouble shooting this crazy thing.
I'm figuring the only reason I'm not getting
spark is either and bad ground or neutral
safety switch, it has to be something simple.
I'll keep y'all posted on the progress.
I have no luck with electrical issues. It's like you said could be something simple, but tracking it down takes more patience than I ever have. Good luck and keep us posted.
I'm not a pro at electrical stuff, just know
enough to be Dangerous..Lol!!!
Thank Gosh I work in the Aerospace industry
and have top notch Avionics Tech to fall back on.
Lol, can into work this morning and had 4 guys
over at my tool box asking me questions about my electrical.
:))). Trying to get as many people involved so that
I can get this crap figured out and be able to go
Sling some MUD!!!! :)))
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Panupong Pradchaphet
