as long as you turn the gas on you will be fine. once you get it there let it on a fours for a few minutes before you start it to get all the oil settled again. but i ve seen it done many times you be alright.
Ive seen quads hauled that way. As long as your not crushing any plastic parts it should be fine. Yes gas off and make sure it doesnt come out of the vent line if it has one.
Sent from my SGH-T959V using Xparent Blue Tapatalk 2
Yes I have seen that done. Like everyone has said, gas off and make sure nothing is leaking or any plastic getting damaged. Strap it good and remember while hauling it that it will now have a higher center of gravity.
  • 5 weeks later...
    • By Trent Finnessey
    • By Dumass
    • By Arizona
    • By Ejwill
    • By Ejwill
