:skeptic: ok guys im havin a problem here.... ive heard tht after u loosen up a stock axle nut it tends to come loose all the time after tht...... well i noticed tht my axle is movin an awful lot and we i ride i hear a rattling sound ..... i looked at it and got to feelin around and the brake disc moves around and the threads the axle nut is on move to....... is this because my axle nut is loose and needs tightened or wat?????
you can keep tightening it, but it will eventually come loose again and damages the bearing when you re tighten all the time.
ok so i need to buy both a new outter and inner lock nut correct???:yes:
