I have a 2004 Suzuki Eiger 400 4X4 automatic and I'm having problem keeping the ignition switch from blowing. The only thing that is different is we broke the tail light lens so I'm looking for one and I wonder if the moisture in the tail light area could cause a short? Any advise would be appreciated I'm pulling my hair out!
did you blow fuses before the broken tail light? i would make sure the taillight socket was clean and put some dielectric grease in there. it might help but it sounds more like a short somewhere. i would be checking the wiring where there are rub points. is the fuse the right amp fuse? i would put the dielectric grease everywhere there is a connecton myself ...
    • By Tim Keiper
    • By Travis_Smith
    • By Mhatayas
    • By KSIM
      View File CFMOTO C-Force 400 service manual
      C-Force 400
