I bought a 200x nt sure what year not running. All the wires from the engine to cdi to cdi box
To spark plug . Got it rigged up and now it has spark- i got it to fire twice yesterday for about 3-4 seconds each time. It has a diff style MIC carb on it. Its gettin gas to the bowl but from there i am not sure. From the carb back there is no air hose idk i that makes a difference or nt. i am lookin for the correct way to connect the ignition system. And does anyone knw were to get a 200x carb for cheap?
How is the right way to test if soark is strong enough? And how to see if fuel is makin it into engine. And wht kinda plug should i be usin? And does the open air hose make a difference?
I can see into the carb but how would i knw if gas is squirtin its nt fuel injected so wouldnt it use vaccum??And the soark is blue i held onto end while kickin it and it shocked me. When i kick it it sputters and shoots pressure out of the carb. Could it be getin to much air with straight ipen carb to engine??
Its a 200x trike- but the carb is off of something else according to the honda dealer . And i cant really see gas squirtin but a white haze in there every once in a while. It smells like gas while i kick it. An it putts once in a great while.. I have takin the carb completely apart and i cleaned every hole.
you need gas spark and air for a motor to run if u have spark make sure ur getting gas then check ur air box if ur getting all that its prolly electrical issue ur have and take it to ur local shop and have them test it it cost me 40.00 to do it
try the mpst stupid crap u can think of i had a 200 es with those its the stupid sh** that dont make it work... try some carb spray or starter fluid in the carb
Its hard with plug in real easy withnout-- and i can see the blur
Spark- and i can get it to fire once in a great while foolin around with it. The carb is open on the intake end and the gas is gettin to carb. But the float bowl is aleays full of gas
Alright it has blue spark, it is getting fuel into the carb.... But still wont start up. Could the spark be too weak? If i hold hand over carb and kick
It my hand gets soaked with gas. The spark is blue but it is a little spark. And i found out the carb is a 30mm aftermarket.
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By DrtyGrlKristin
    • By Mech
      View File TGB Blade-Est 1000 service manual
      Submitter Mech Submitted 09/10/2024 Category Other ATV
    • By pitts
    • By HondaPhile
      Fixing up an old Honda for my son,  Looks like a great site for info and resources.
