you gotta make sure you cleaned it good and used twist ties through all the passages. if you did, then disreguard above statement. there is an air/fuel mix screw on the bottom of the carb and an idle screw that should be turned out 2 - 2 1/2 full turns on the side beside the pull choke ...
    • By Tinkeringreg
    • By Dumass
    • By Trent Finnessey
    • By DPDISXR4Ti
      Thanks...
