i need help with replacing rear axle bearing on yamaha big bear 350 1997 2X4.
i got to remove the one on the right (closes to the wheel) now i need help on the side of the differential..i do have the axle off....i got part of the bearing off as it fell off once i remove the seal...the outside(the race) of the bearing is still in there ans it is bigger then the hole(gear inside the diff) there for i cant really put tools on other side to tap it off.. lice i did the opposite side...im stuc with the race on the side of the diff not nowing how to remove.. please help.... i aslo need help with whoble front drum braces....the wheel whobles when the drum are on the shaft in front... bearings and everything is fine...how to tell if it is the proper drum that is on it..?there seems to be some slight wear inside the drum where the 4 studs are....really slightly but stil... alright any help would be apreciated. thanc u..
that is it.. i need to replace the number 10 and 11... i got the sea off easy...the axle also...i only need to get the left over of part number 11(the outside part of bearing) that is still inside there.... how to get it out..? cant put anything tru the frame from right to left to the bearing cause in the diff there is a gear and that gear is smaller then the race of the bearing... that why im stuc....need some advice thanc you.. and thanc you for that schematic....
i had to remove the rear diff and open it and then remove the bearing that way.. then put everything bac together...... i did not however remove the plug from the rear diff... by splitting the diff in half then the oil came out but for next time dont no how i will do it......will see next time......
    • By Thumpinhard25
    • By fwsamm
    • By carkivey3
