By BuckBilly
By Kawasakibayounospark
By neilroy87
I have a 1990 Bayou 220 that runs pretty well for it's age--needs a new muffler, but sounds tough. Have had to start with a pull cord since I got it, and recently started troubleshooting the start button. Finding a lot of information on this issue in the forum, but haven't been able to chase it down yet. Got a new battery, new starter solenoid, and going to replace the starter relay this week, but not convinced that's going to do the trick, since I can't get the neutral light on when turning the key on. I can start it by jumping the solenoid, but the 2 black wires to the relay do not activate the starter. Bad ground or a short somewhere? Is there a good way to just test the ground?
By beast6228
However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it. If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
By Ajmboy
View File 1986-2006 Kawasaki Bayou 300 service manual
This service manual is for a 1986-2006 Kawasaki Bayou 300.
Adding to downloads library.
Submitter Ajmboy Submitted 05/11/2018 Category Kawasaki ATV
