Hello from Vermont
By BuckBilly
By P_syko
By KdlH
Hello.
Thanks everyone,
Kester
By Vlaco
Hi. I just joined the community. I have a sheep farm and use a Polaris 500HO, Polaris 700efi and a JD Gator 825i for different jobs around the farm. I do all the repairs myself so I am sometimes needing some advice and maybe I can be of some help to others as well.
By Gwbarm
Just aquired this Honda 4514. I had heard of them and seen them but had never really looked at one. Amazing machine from the 90s.
It has a 14 HP inline 2 cylinder engine. A cute little fan like the old school cars had and a little radiator. It has a timing belt on the back of the engine running the cam and a water pump. Just like a miniature car engine with electronic clutches to turn blades on and off. Pretty hight tech for the 90s not a small thing and built like a tank weighs in at 600 pds hydrostatic trans. I have found out that almost anything you have to do to it the engine has to come out starter timing belt water pump. Very expensive parts i think most got junked for that reason, i did find out they were built by John Deere except for the honda engine.
Does anyone here have any expierience with these.
