By onequad
i got a 93 400 Kodiak the frame on one side is rusted out. is this a comin thing? was wondering if it worth the tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
By BenJammin
By joshua91673
first post
josh ohio
By n4cer26
Just bought a non-running 425 Magnum 6x6. Guy said previous owner had motor rebuilt (3 years ago or so.) It reportedly ran great but recently the electric start began failing and he put a new recoil on it which he broke immediately.
I get it home and put a new recoil on it and the pull is incredibly hard....so much so that I think I'm going to break the new recoil assembly. I also installed a new starter which won't roll it over either.
I'm thinking maybe a hydro-locked situation so I pull the plug and the motor rolls over fine with both pull start and electric start. The cylinder was dry however.
Checked the valve lash and it was right on at .0006".
Checked the compression relief spring on the end of the cam and the spring was strong and keeps the metal piece against the dowel like it should. The cam lobes look good from what I can see.
I have a small camera that I dropped into the cylinder. Could t get a pic of the entire chamber because of the angled engine but there are marks on the center piston and a couple of grooves once side of the piston top. I will include the photo.
Anyway....I'm at a total loss at this point. Not sure how to proceed and diagnose. Would sure appreciate anyone's help who might know what the heck is going on! I was able to get it to turn over about 5 times with electric start with compression tester installed which read 145 lbs. I don't know what else to do!
Reply
Sent from my SM-F926U using Tapatalk
By CaseFabrications
Since the very first ride after I bought my boy his DS 70 (2018) I have had an issue with it cutting off after splashing through water and not wanting to start for a minute or 2 waiting for wherever it is to dry off that is causing it. I went through and put dialectic grease on all the connections and it continued to do it. Not nearly as bad as before but still. Today before we went riding I put a good bit in the spark plug boot but toward the end of the day it started doing it again. Do y’all have any ideas on what might be causing this and a solution? Also I buy and sell wheelers a lot and it seems like every little one I get when I break them down to clean the carbs all the dry box and boots and what not seem to be siliconed. Is this standard practice on these small ones or just coincidental that I keep getting them that way?
