I'm looking to get a YFZ 450 and I'm wondering how much benefit I would get from buying an 09 or newer. I hear carbs can be a hassle but is it really that big a deal? Btw this will be my first quad since I was 12 years old. I have ridden street bikes quite a bit and I never had any problems with my carb. Educate me?
i like the idea of it myself ... here is a good read from venom performance ...
Fuel Injection: Better than Carburation?
It's easy to think of Fuel Injection as "an electronic carburetor replacement". Because it truly is no more or less than that. It is a device that mixes fuel with the incoming air so that the mixture is ignitable in the combustion chamber. Fuel Injection can be a wonderful thing, but it isn't as simple, or reliable, as carbureting. Fact: there is a lot more things that can go wrong with FI than with a Carb. There is the same power potential with both, too. Neither one forces air into your engine. They are both just ways of mixing fuel with what airflow the engine is pulling in.
1. Decades before there was Electronic Fuel Injection, there was Mechanical Fuel Injection, even on some of the first Corvettes, although they weren't the first of their kind. Both types still fall under the parent category of Fuel Injection.
2. Unless you have a dyno that is A/FR meter equipped, a person isn't going to have clue one about how far out they are from correct jetting, or any idea of how much adjusting it will take to get to correct either. You could adjust all you want, but without before and after runs on an AFR equipped dyno, you are just throwing darts in the dark. Venom does have an in-house Dynojet Dyno, along with the $3000 A/FR wideband meter, and the Power Commander tuning setup on the Dynojet's PC. And it still takes time and experience to dial in a correct A\FR map for a modded machine.
You can make a jetting adjustment for every change of 250 RPM, plus those changes need to be mapped at those RPM increments over discreet throttle settings from near closed throttle to wide open throttle. This is all because the mapping for 5000 RPM at half throttle is WAY different from 5000 RPM under full throttle, as well as snapped open full throttle from 3000 RPM. You get the picture. There are literally hundreds of adjustment points that cover the injector setting mapping from all rpms and all throttle positions. So, as I said, change ANY component that changes airflow and you need different map settings.
The ATV manufacturers could certainly supply fuel injection units that are self calibrating, changing the maps themselves based on factors like:
Air Density (which takes into account altitude)
Air Flow
Temperature
Oxygen content measured in the exhaust
But they don't. Their systems are just about as basic as EFI can get, and their self adjusting is VERY limited. So much so that pulling an airbox lid and pulling the spark arrester out of the exhaust REALLY stretches their capability to the end of safe A/FR ranges. In that regard, the FCR carbs currently on machines have a wider range of self adjustment than the current crop of A/FR systems on ATVs. The carb's metering can and does adjust based on mass airflow through the carb's venturi. More airflow means a stronger vacuum signal, which means more fuel will be drawn into that airflow. Not a wide range for sure, but you get the jets in a decent range for the current mods of the machine and actual airflow will change what gets metered through it to some degree.
Put more air through the current crop of EFI on the ATVs, and since there is no vacuum sensitive part to the injector's metering, the EFI just basically knows RPM and throttle opening, NOT actual airflow, so it just sprays the same amount that the map tells it to for that RPM and throttle opening until someone dyno AFR's the setup and re-writes the mapping.
Another thing: whatever "MAP" is loaded into the Power Commander module contains several hundred points of jetting to cover the grid of throttle opening VS RPM. All of those points have a huge range of adjustment when using the PC3 program on a computer, but the controls on the PC3 module itself only allow for a bulk 10% change of the downloaded base map's curve, and each control "button" makes for bulk changes to approximately 1/3 of all the RPM\Throttle control points in the base map.
So if you get the base map tuned dead on for the center point of all the AVERAGE conditions you ride in, like temp and altitude, and don't change any engine mods, you will have 10% bulk mapping curve adjustability on the controls of the PC3 unit itself.
Once again, with the current crop of basically NON-self-adjusting EFIs on ATVs, all of this is predicated on a correct base mapping as tested and tuned on an A/FR equipped dyno over all throttle settings and RPM's. Anyway, the primary focus of this thread was to address all the question "How much HP does fuel injection add to the new machines" that I have been getting.
For all the potential benefits of a high end FI system, which the ATV's do not have. The HP answer is still the same -- no difference at all.
Properly tuned CARB and properly tuned A\FR are equals for power output.
I will say that A/FR, with all its dependence on computer control, injector action, fuel pumps, and filters to save the pumps and injectors, is a far more fragile system than a simple/mechanical pressure differential metering device like a carb.
If my life depended on a particular off road engine's 100% reliability, I’d still take the carb.
The fact is that when an FCR carb is open, only the thin needle remains in the airflow path, but when the throttle body of EFI is open, you still have the whole butterfly and shaft assembly in the flow path.
If someone were to buy a Fuel Injected ATV with the systems they currently outfit them with, and never plan to do any modifications to the engine, they would be just fine. Although they would still have more weak points of potential failure liability -- CPUs that can burn out, fuel pumps that fail, electronic injectors that can stick, filters that clog, and TPI's that give the CPU bad readings. And all of those components are NOT cheap, and NOT cheap to troubleshoot either. BUT, given the fact that most people buy sport quads with the intent of making them faster, you would need to dyno a\fr re-map for EVERY single mod you do the engine, not to mention immediately needing to buy a PC3 CPU that is programmable in the first place, so it would be best to break the bank and buy everything you ever wanted to put into your engine mods and then custom dyno tune it all in on only one occasion.
So, even if the manufacturers offered better/self adjusting FI systems, they still have all the potential failure areas that were mentioned above. But the least the manufacturer's could do for sport off-road machines is offer the best of what's available in EFI from the beginning.
Venom Performance
Venom Performance
you can get more power and atomization of fuel with fuel injection. i think it's just more convienient and easier to replace if you have problems, but more expensive too. easier starts too i think, i would buy efi over carb on my next one for sure.
Edited by oxidized_black
Alot of that article was talking about was non programable fuel controllers though. Most of the products I've looked up say you can add maps pretty easily. Now I just need to decide if I want reverse or not.
yes, i'm not sure how long ago that article was written, but improvements are made every 6 months or more. i would also get reverse, it's handy and a good resale option on a bike.
and i'm sure i could find an article that is a complete 360 of what you just read too.
Not speaking of atvs but cars. Todays efi blows away any carb. From easy starts to self calibration of a/f through all throttle positions. Turn the key and go is the norm. Do fuel pumps and modules go bad? yes but not often. There is hardly any maintenance on cars now. I am constantly fussing with my atv carb. Maybe i am not a carb expert but i wish atv efi was on par with automobiles.
Sent from my SGH-T959V using Xparent Blue Tapatalk
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Frank Angerano
